ok, i've removed everything. i've removed the splines from the swivel hub. The only problem now is getting the driveshaft to come out the gear box side. do i just need to keep pulling? there is no roll pin is there? please help!!!
i use williams driveshafts but the o/s splined section on my JC5 has the hole for it, so i would assume (we all know what assumption is lol) the 172 driveshafts have them too?
if there is no roll pin i find a rubber mallet does the trick if it's stuck
hi fella yeh my bad reading that you had taken everything apart i thought you had done the roll pin 2.. it can be found on the gearbox end of the drive shaft...if you pm me your email i can forward you the renault handbook of that operation for you in pdf.. and its in section 21-5
right. thanks for everyones help. b*****d deffo wasnt budging and then it started snowing so i thought balls to it. ive put it back together and its booked in at a garage. first time ive had to accept defeat with doing work to my car and it should have been so simple!
