Help!!!
Car  NEED V6!
Noticed that the steering pump had fluid all around it and the two pipes that lead out from underneath it the one that connects around the front of the engine as all the hydralic fluid is covering what looks like a spring of some kind.
check the sensor attached to the dark green pipe - this leaked on mine. They cost about £50 to replace.
Try tightening carefully if its loose - but dont swing off it because you'll snap it off.
yeah I can't actually see any green pipe may have to give it a good clean in the engine to see!!!
