Clio 182, Mercedes,
Hi all can I start by saying what a great community you have here!!
So my problem is my sons Clio 182 2005, he broke down just as the covid lock down began and I’ve only just managed to get his car home obviously being a 182 this was via a tow rope
The car wouldn’t turn over so 1 tested the starter motor which was faulty so I’ve replaced it and works a treat, my problem is that the car won’t fire.
Ive put my diagnostics machine on it and all I get is a fault with the front oxygen sensor, I’ve check the coil pack And I have spark on all four plugs, I can hear the fuel pump priming and when I removed the fuel line from the fuel rail I have plenty of fuel pumping through as I turn the engine over.
ive also replaced the TDC sensor even though it wasn’t picked up on the diagnostics machine, the car has a new battery on it and I have compression.
to me it seems like the car is suffering with fuel starvation, have Any of you ever had something similar or have any Ideas what the problem might be.
thank you in advance any help would be much appreciated
