hi help please
Car  clio dynamique 2004
as well as the problem i have with the airbag/service lights coming on following a valet(posted elsewhere), i now have an issue that I have just discovered on my new clio(a 2004 plate diesel dynamique)-the switch under the milometer used to access the tripometer doesnt work.The milometer works and records mileage but preessing the button does nothing.Only a niggle but wondered if there may be an easy fix?
Airbag light is the connection under the seat (could be either driver or passenger side) - if you search the forum you'll find the fix - always search first.
As for the other issue, you'll need a new stalk.
Press the end of the wiper stalk and it will move to the trip meter. Then press the button under the milometer to reset to zero. Press the end of the wiper stalk repeatedly and it will go through the functions, reset to zero as before.
