hi i have the chance to buy some nice looking fox alloys for my car they are possibly fox rs6's however i need to know if they will fit my car the seller tells me the code is 14x51/2JJ will they fit my 97 plate mark 1 reanult clio?
sounds like they are 14" diameter and 5 & 1/2 inches wide. Thats not enough info. You need to know the PCD (thats the spacing on the bolt holes) the offset (in ET, this basically tells you how far in or out of the arch the wheel will sit) and the centrebore (the size of the hole the hub sits into but this can be got around with spigot rings if the other numbers all work out)
