Higher Dipped Beam
Car  Clio 197 R27 Albi
Anyway to rise up the dipped beam a little. Mines a bit too low for some reason?
If so how?
Would that be the one which you can see which is attached to the electric adjuster or is it behide the projector light its self?
adjust the white adjuster with an allen key (8mm i think).... one side is easy, the other is a f**king nightmre lol....tight as a nat ass...... you are in danger mot fail btw, some garages will fail you instead of just adjusting it back....
i disconnected my auto balancers on my 182 ff and adjusted the HL's myself..... i never had an mot as it was less then the age required (3 years ?)...just drop the height if you find people flashing you...
