Horn isnt working
yer but how will i know if the fuse has gone ?..
thanks
oh dear... if the fuse has blown there will a visible break in the wire, the one for the horn is in the dash IIRC, inside the passenger door shut. If the fuse is ok, try taking the horn off, sanding the connections and putting it back on.
8 times out of 10 its the actual horn itself, and the other 2 times its the steering wheel slip ring. Get a multimeter and check its getting a feed, if so its the horn at fault, it is a very very common problem.
