Horn location?
  Renault Clio 182
Hi, can anyone tell me where the horn is located, looked under the passenger side lights but unsure which wire i am looking for.
Darren S
If you're there with the arch liner unbolted, you might as well insert two non-return valves onto the headlamp washer pipes. They run close to the horn and would stop that stupid weeping that drips out of the drivers' side headlamp washer. :)
D.
Yarp
  Clio 182, E46 M3
Mine is currently sat on a shelf in the garage as it was in the way of my brake cooling ducts.
However, as above, it should live behind the passenger side arch liner. You can’t miss it. You can just see it here in this pic.
Darren S
When I had my arch liners and front bumper off the other week, a non-working horn was one of the issues I was going to fix.
Disconnected and reconnected each end of the black and white wires in turn - and with each, scrubbed the crud and crap off the connectors with a little wire brush. Added a little bit of dielectric grease to the connectors also and the horn works a treat now.
Louis
I Love Ed Sheeran
However, as above, it should live behind the passenger side arch liner. You can’t miss it. You can just see it here in this pic. View attachment 1719988
I have some horns I was going to fit at the front when I turbod if you want them?
