im interested in this too ive got to fit one to mine monday night after work. i looked at it and thought scuttle front bumper and lights needed coming off?
Its easy to do as Ben said a few bolts along the top of the panel under the bonnet plus one sort of hidden under the scuttle panel from memory.
There one when you open the door by the hinge
Then idealy jack the car up remove the wheel and the arch liner (the clips just pull out) Then theres two bolts which face upwards as such and bolt the wing to the bumper.
Then theres the one or two right at the bottom of the wing on the outside of the car.
Then theres one sort of holding where the mudguard would be.
fitted mine tonight quite easy took 2 hours though.
had to take wiper arms and scuttle panel off,
release all wheel arch liner
3 or 4 bolts along the door shut
2 on bottom of door
2 along top of wing under bonnet one upside down
2 bolts for bumper under wheelarch spat need to be released and bumper pulled forward
headlight forward to release pin that goes through wing.
not quite as straight forward as i first thought but still ok - hardest bit is setting up all the gaps (being a non genuine wing)
