how do i remove the standard head unit off my T reg clio? Help :)
its a VERY quick job, if you have the pins, its a 10 sec job!
probly look like those.
Isnt really the hardest thing to do rach!
If you nip to halfords and get the tool should simple pop in and then pull it out and headunit comes with it!
Then at the back there are 2 ISO wire blocks, just take them out and put into the ones that come with your new headunit!
ok put them in the holes as far in as the can go and pull them appart as far as you can and at the same time pull outwards it should eventually budge
It can be a complete C**T to get out, mine was, literally foot on the dash pulling as hard as i could...
Extreme test of strength... lol
Let us know how you get on...
Really simple, just a bugger...
Sam
Its easy get 4 strands of cotahanger wire and stick then about 2 inches down each of the hole then use them as a sort of chinese chopsticks to pull the unit out.
