Take the heat shield off above the centre section, its right in the middle, its held on by 4 very tight torx screws. Once the heatshield is off you will see an adjusting nut on the cables.
I had to use my powered torque wrench to get the screws off, they were very tight for some reason.
actually its only 1 nut you adjust to tighten it up, i recommend a deep 10mm socket, not the normal depth one. and you only need to undo half the heatshield one side and just bend it down (torx)
