How easy is it to remove rear difuser?
As a brick must of flicked up in between the exhaust and difuser and is now rolling around in there! Annoying...
Easy, few torx 20's iirc. It then clips into the bumper around the number plate. Take your time and you'll be fine :)
Good access to the exhaust tips too ;)
Yup, off memory, there might even be a few 10mm bolts in there for good meaure. Its pretty straight forward. Hell, i took mine off :)
Brick/pebble/stone? Or maybe screw? Who knows?
But there is something little rolling around in the difuser, you can hear it sometimes when you go around corners. Can only think something like a brick has flicked up between the gap of the exhaust and difuser...?
Will keep you all updated of what it is when I get the difuser off.
