How low can i go
  197
Hey people. How low can i go on springs without causeing damage to the drive shafts and other components?
cheers
toon
  Clio 200
the lowest you can go on springs alone is 40mm anyway which is apex springs, anything lower is coilover materia
  4 wheels
theres only to springs id reccomend eibach prolines or eibach sporltlines dont lower it load but handle alot better. i think apex doe spring but there alot stiffer
When you lower the car besides the point where the steering arms and driveshafts are at a sharp angle (conidering that at stock height they are parallel to the ground) you will run into:
- Bumper steer
- Premature wear of driveshaft bearings
A lowe car migth look good but it doens't mean it will handle better.
  197
i dont wanna lower it to like 70mm or anything like that. I was looking more around 20-30mm. The only thing im worried about is driveshaft and suspension arms
