How Low on 17 rims
Hi to everyone, i drive a 1.4 Sport 8v and was hoping someone would be able to tell me
if a 60mm drop on 17"s is too much or not? Only had the car for about 6mts now so not
too clued-up on clios. Thanks in advance.
I dont think youll have any problems. Youll need to get uprated dampers/shocks if you go that low though. Im not sure if your car is a fitment but spax to good value coilovers (RSX?) which obviously include shocks.
-Rob
FIrst post of 2003 :)
mine and freds are lowered with -60mm Pi springs and 17s, no rubbing at all even with 5 on board, for the non 172 models -60mm is about right with 17s, the tyres sit flush with the arches, if youre on a budget than springs would be fine on its own, had my springs on for 8 months and the shocks are still in good order, the grip/ roll resistance still improved by a fair margin. atm comfort is acceptable so i dont know will harder shocks will be suitable for our roads....
Well id expect theyre not suitable for UK roads, but -60mm wont help in the first place. If youve got 17s on a small engined motor you might as well go for the shocks too as even though your shocks will be ok for now, theyll wear. It will improve handling after all.
If you think about it a modded car is only going to be bought off you by another enthusiast, no one else will touch it, so you might as well go the whole hog or not bother at all.
Tom
  EV (s)
But there are no shocks availble that support that kind of drop anyway
at least i havent found them
mines dropped 60mm on pi springs too but i have 15s i dont want 17s coz the car is going soon
the shocks will be fine just dont go rallying!!
On my mk2 172 ive lowered it 40mm all round on apex suspenson on 17s 40mm off set but i needed 2 get the arches rolled but its fine now no rubbing. If ur getting 17s and lowering it 60mm ur better off getting a 40mm off set if u were just lowering it 40mm then a 35mm OS would be ok, its just the 172s have a wider track than the normal clios so thats y i got the 40mm OS, 35mm is for normal clios but if ur lowering it 60mm then ur better off goin for a 40mm OS.
as ive said above if you are on a budget than springs alone is more than fine, as i dont think harder shocks will improve the handling THAT much, unless you are on nice pothole free road, which is something very rare in this country.
not sure ill sell the car with the mods, itll be easier to sell a standard car than a modified one
personally, if i was u i wouldnt get 17s stick simple, no bigger than 16s! 17s look a bit ott i think, unless on a 172. but with a 172 u got the power already to be able to afford to stick 17s on. oh and if u got the 2000 1.4, whack a piper x air filter on, if u aint already, trust me it will b loud, my mate had one, OMG
Matt
heard a lot of bad things about spax from various poeple, leda are very good for custom shocks, can build you a set for a reasonable price
Fair enough. Im still pondering about what to do with mine, either leaving it standard and waiting till i can afford the 172 or going mental. Ill be waiting another few years till insurance gets reasonable and im not sure how long i can last in a standard car!
Remember arch clearance is greater on less models. You can fit 19s on 172s without scrubbing (or lowering though!)
get 16s/17s on it and lowered it, youll love it, than wait till your ncb build up and get a faster car, hopefully ill be driving a vtec next year
Tom
  EV (s)
ok ok peeps lowering a 172 40mm is the same as dropping a standard non 172 clio a whopping 75mm!!
so in reality any 172 lowering problems are excluded for normal clio owners 98-on
Unless (like fred) you intend to go 85mm on coilovers
  Turbo'd MX-5 MK4
i had my 2000 clio lowered 60mm on 17s and the car now needs a new wheel bearing, something to bare in mind, IMHO the car cannot take 17s with that big a drop.
  Turbo'd MX-5 MK4
Speaking from experience i would go for 17s and no more than a 35mm drop, the 17s look so much better than 15s or 16s and give more grip, and with a 35mm drop the car will be quite good to look at, i originally had mine on 35mm Eibach Springs on 17s, then i went for 60mm on the same 17s (after my mate had he 106 GTI lowered 40mm), but i wish i hadnt, the ride was absoloutely horrific, the car looked fantastic, but was very impractical, also, when it was lowered 35mm there was no scrubbing at all no matter what i did, but when it was 60mm on full lock on uneven ground it scrubbed (nothing major though).
Ben - I mean just using springs. As you know ive commented in a million threads about how wrong it to just have springs if your going more than -40mm.
My new clios ride isnt that good, my dads M3 has 19inchers with 35 profile tyres. The front suspension isnt that impressive, but its still better than my car which is unmodified! I think ill wait for doing the serious stuff when i actually get a performance car and the backache will be worth it!
I wouldnt put 40 off set wheels on a clio, its pure wrong!
Youll need to replace your wheel barings on a standard clio with 17s no matter wot drop ya got. if you lower it 60 and dont uprate your shocks youll fail MOT before you even drive it in, although theres nothing wrong with it at the time these guys know the implications off these types off lunacy.
Uprated shocks dont neccessarily have to be stiffer than normal 1s just mean they can handle the drop bettert han standard 1s.
If i was ne1 id buy a whole kit. Apex kit is onlt £233 and the K-tec and G-max kits srent that far off either.
Thought id let u all know i fitted the wheels and springs with no problems. No rubbing. 60mm drop on 17inch wheels with a ET35 offset. I suppose u just dont know till u try it for yourself! Thanx everyone.
-Paul
ME551E wot u talkin about a 40mm off set on a clio is pure wrong! If u no clios then ud no that a 40mm off set on a 172 is equivalant 2 the correct 35mm off set on a normal clio
  clio 20v
IMHO if ur goin to drop it 60mm just springs are alrite unless the springs lift out of the shock cups and they dont bottom out straight away with cut down bumpstops
if ur cars done a few miles its prob better if you just get a set of replacement original shocks there life will be shortened but they will prob live how long u own the car
most sports shocks non-adjustable are too hard for the road specially on 17s with a 60mm drop most people wont put up with it and the handling will suffer unless ur on flat roads, most sports shocks are shortened anyway id go for a set of adjustables though
adi
I dont see how it would fail an MOT just for dropping the car 60mm? MOT is safety checks only. -Sure if the wheels are hanging off etc it would fail but I know loads of people with 60mm drop who pass MOT every time
I went for a set of TSW Reflex, with yoko tyres, and PI springs. I do find that it tramlines real bad, and its real hard. But what the hell, it looks good!
Paul, i was reffering to this guys question, hes driving a 1.4 which is an offset of et35. so and offset off 40 would end up damaging his car.
I dont know about England but i know a lot off people who have dropped their clio on Pis -60 springs and the MOT guys have said "that drop is not safe on standard shocks". just stating my experiences, ya can listen or ignor me. At the end off the day im giving my advice just as every1 else.
The ride on the coilovers is actually very soft, its all relative I suppose, I am swopping the springs to HandR ones to see if that would improve. Dont think it handles any better than on my Prima Springs but can be caned down B roads at silly low ride height, think there are pictures somewhere in the gallery, how do you show pics on the forum?
Tim
