Quote: Originally posted by RobFenn on 02 January 2003
Well id expect theyre not suitable for UK roads, but -60mm wont help in the first place. If youve got 17s on a small engined motor you might as well go for the shocks too as even though your shocks will be ok for now, theyll wear. It will improve handling after all.
as ive said above if you are on a budget than springs alone is more than fine, as i dont think harder shocks will improve the handling THAT much, unless you are on nice pothole free road, which is something very rare in this country.
If you think about it a modded car is only going to be bought off you by another enthusiast, no one else will touch it, so you might as well go the whole hog or not bother at all.
not sure ill sell the car with the mods, itll be easier to sell a standard car than a modified one
Quote: Originally posted by Paul172 on 02 January 2003
On my mk2 172 ive lowered it 40mm all round on apex suspenson on 17s 40mm off set but i needed 2 get the arches rolled but its fine now no rubbing. If ur getting 17s and lowering it 60mm ur better off getting a 40mm off set if u were just lowering it 40mm then a 35mm OS would be ok, its just the 172s have a wider track than the normal clios so thats y i got the 40mm OS, 35mm is for normal clios but if ur lowering it 60mm then ur better off goin for a 40mm OS.
Remember arch clearance is greater on less models. You can fit 19s on 172s without scrubbing (or lowering though!)
