Clio
With 3, 4, 5 or 6 point seatbelt harnesses available, which one to go for? What are the advantages / disadvantages?
if your seats are on a subframe then they should have a harness mounting point on that subframe on the handbrake side. Then for the door side you can mount it to the original seatbelt mounting point. For the back you can mount one of the straps to the original rear seatbelt clip mounting point and as i own a mk2 i cannot suggest where to mount the other strap for a 4 point
Well, I bought a pair of tasty four pointers. Understand from post 7 where to put first two points, but can't work out for sure (even from the link in post 8) where the best points are behind, assuming no cage.
No one on this forum yet seems to have posted clear photos of their mounting points (ooo matron).
