How mcuh snow foam?
Just a quick question, how much snow foam do I put in the i4detailing bottle? Also do i need to mix it with shampoo?
  titanic killer
as above and also dont bother hoseing the car down first as i find the foam just flls off insted of sticking best straight on dry car tbh
  Fiat Coupe 20vt
With the snow foam you can fill the bottle up to a very strong ratio and use the adjuster on the foam lances to regulate the amount of snow foam that is pulled through. If you find yourself emptying the tank to quickly even on a full ratio setting just increase the amount of solution in the tank and knock back the adjuster.
That way you will also not have to fill the tank as often.
Tim
  Clio MK 4
Ye as above. You can adjust the amount and how much it spreads. I also find once you fiulled the bottle up, cover the top and give it a quick shake then connet it up. It foams even more!!!
