How much can it take
Whats the maximum output a standard F7P and gearbox, drivetrain can handle? Just wondering how much NOS I could get away with on a standard engine before something went bang.
  BMW 320d Sport
Well mines taking around 250bhp. I can tell you through experience with this sort of thing that itll take 100 extra hp no problem as long as you dont try it from a standing start. Go easy on your clutch and itll last a long time. The gearbox is safe cos the clutch will go first. The lump will take that amount of gas as well, no problems yet.
  BMW 320d Sport
Half a dozen proper standing starts even with only 50hp of gas will knacker any road clutch for good.
You need to consider other problems, like Fuel Starvetion !
You may need another fuel pump !!!
Has anyone upgraded their fuel pump, or added another one ?
If so ,wich and what have the done exactly ?
Well Ive got a progressive controller, and Im getting N2O and Feul pressure gauges soon and an Air/Feul ratio metre, is it possible to fit a incar adjustable feul regulator that would noly adust the pressure goging to the feul solenoid? I wanna be able to run a true 100bhp extra, not just 100bhp jets if you see what I mean, just wondering how much higher you could go 125bhp, 150bhp?
What sort of power do you launch at and what soet of build up time do you use?
  BMW 320d Sport
Well I already had a power boost valve IMHO not the greatest mod in the world for a standard-ish car, but bloody handy when youre running gas. I have a fuel pressure gauge tapped into the side of mine so I can alter fuel pressure according to ambient temperature; that way I get a consistent correct AFR from the gas which obviously varies pressure according to the bottle temperature.
My system is set up like this: AFR gauge to keep an eye on the ratio; fuel pressure gauge to allow accurate adjustments whenever necessary (the chip takes care of the normal fuelling of the engine); nitrous pressure gauge so I can keep an eye on pressure and expected nitrous delivery rate; progressive controller set up at 50bhp-100bhp with a rise time of 2.5 seconds.
I can do a normal 5000rpm standing start, feeding the power out carefully then as soon as Ive got traction in the first second and the revs are holding at 5000, floor it and the gas fires at 50bhp, change up and floor it straight away where the controller resets back to 50 again, keep it floored, by the time Im at around 7000 revs, the gas is at full power 100bhp, then if I need to change up again, it resets to 50hp at around 5500 revs.
This is the system that enabled me to keep up with an RB5 even though I had a bent driveshaft and a gearbox full of shredded bearings! As Ive said on another thread somewhere, you should aim for as much power as your car can take, not necessarily a numerical figure of 100 hp. If youve been driving your 16v long enough, you can feel when its right and when its struggling. Eg over in France I had the 100 jets on but without the controller cos I hadnt wired it up yet. Under street-racing conditions where I was firing the system at 100hp at around 3-4000 revs (earlier than usual to compensate for not being able to use it at all lower down), it was very quick but I could feel that that amount of power in a single sudden hit was killing the engine or at least the drivetrain. I wouldnt be confident about putting anything over 100hp jets on it, my feeling is that thats about the limit, with a controller. If you want more, its time to think about an engine rebuild, lower compression etc.
