How much for throttle bodies on a Willy
How much would it cost to have a throttle body conversion done for a Willy?
Im assuming that the conversion would come with a custom ecu to handle fueling, etc?
Anyone had this done and if so what BHP are they producing?
Simon
you might want o consider the weber alpha kit instead which is basically a 38mm twin choke carb with a potentiometer added so you can control fuelling wit an ECU. probably a grand cheaper than throttle bodies and just as good.
  Clio 172 cup
Throttle bodies on a willy if set up properly will give you around 210bhp but you wont get much change out of £2500!
