How much to swap front dampers ?
Car  Clio 182
Hi guys, I recently bought a Clio Trophy which had failed it's MOT on a leaking Sachs damper. The previous owner had renault replace the dampers with Cup dampers and removed both front Sachs dampers for refurb. The car is therefore driving (very nicely I must say) on Trophy springs with Cup dampers.
When I want to put the Sachs dampers on I am wanting to confirm all a garage will need to do is;
1) Remove Cup damper completely (thus removing the spring)
2) Compress spring and fit Sachs dampers
3) Refit complete damper and spring to the car
I was quoted by a local motorsport indy (not Renault specialist) 4 hours (£200) for this job which seems a little steep to me.
Would the alignment NEED to be reset? I am thinking not.
Are there any good indies either around West London or Gloucestershire who this forum could recommend? I obviously want the job done right and have the car drive as renault intended.
Many thanks.
Very easy to do yourself mate
Thanks Don. I appreciate it's pretty straightforward but I don't really have time. My driveway is on a hill with gravel and after doing a oil change on the family car I just would rather pay someone to do the job. I also don't have spring compressors or suitable jacks etc..
Can I confirm other than compressing the springs it's just bolt on and bolt off? There is no ride height adjustment or tracking setup required??
