Sam, your belt skipped?![]()
Genuine question - how would you quantify any OOR in guides/stems without a small bore gauge & micrometer or alternatively a dial gauge? Chip?![]()
Yep, a small bore gauge will fit & 'seemed' to give meaningful ref of each axis & any taper in the guides in relation to the stem measurements.
Using a dial gauge to measure side float on the valve was a ball ache and found it tricky to get consistent readouts on mine.
Just curious how us mere mortals would determine at what point in the acceptable tolerance they were too worn.
Would most of the f4rs out there have 'some' degree of ovality/valve float yet still sit within tolerance?
I think its only ones which have had hotter cams that are really likely to have issues, in the main the F4R guides seem to last very well.
Yeh got another one with a slipped belt but I don't want to spend a fortune replacing valve guides if possible.
How much are we saying is too much then guys? Or just check them and find the ones that are worse (if that makes sence)
