How to check for worn valve guides?
Car  172 Rally Car
Is it simply a case of sticking a valve in and seeing if it has any side to side movement?
Regards Sam
Sam, your belt skipped? :(
Genuine question - how would you quantify any OOR in guides/stems without a small bore gauge & micrometer or alternatively a dial gauge? Chip? :)
You wont realistically get a gauge in there, best you can hope for really is get some accurately machined pins to use as feeler gauges to check the size in both directions and see if its oval or not.
But I just go by feel with a valve to decide if they need doing or not.
Yep, a small bore gauge will fit & 'seemed' to give meaningful ref of each axis & any taper in the guides in relation to the stem measurements.
Using a dial gauge to measure side float on the valve was a ball ache and found it tricky to get consistent readouts on mine. :(
Just curious how us mere mortals would determine at what point in the acceptable tolerance they were too worn. :)
Would most of the f4rs out there have 'some' degree of ovality/valve float yet still sit within tolerance?
Yeh got another one with a slipped belt but I don't want to spend a fortune replacing valve guides if possible.
How much are we saying is too much then guys? Or just check them and find the ones that are worse (if that makes sence)
I think its only ones which have had hotter cams that are really likely to have issues, in the main the F4R guides seem to last very well.
For example. My mrs old 172 has done 151K miles
When I pulled it apart at 141K miles, the valves felt so good by hand I didnt bother changing the guides when I put it back together, its been perfect for another 10K miles since, about half of which was clocked up on trackday or ring trips so not exactly being pottered around, even on the drive back from the ring it was at nearly 6Krpm for 2 hours at once point (late for ferry).
Furry muff :)
Ah right :)
Assuming its a 736, tolerance is listed between 5.462mm to 5.480mm on the inlet valve stems and 5.438mm to 5.456mm on the exhaust valve stems.
The clearance tolerances are listed as 0.020mm to 0.056mm for the inlet valves and 0.044mm and 0.080mm for the exhaust valves.
