Quote: Originally posted by hydeyho on 31 August 2003
Jonesy, just seen the photoshop pics of your car in the media forum. How much did you pay for your double optic headlamps and the spotlights? Did you fit them yourself? Were they an easy job?
Hi, the headlamps I bought were from
http://www.andyspares.com/SPAN style=COLOR: windowtext"> www.andyspares.com/SPAN they are the £45 each and they are brand new, look for Clio sport 99>. Fitting them was fairly easy, you need to remove the panel under the grill part between the headlamps to get to some screws to get the headlamps out. They fit straight in after that, but they also need to be rewired.
I did the rewiring with a m8 and his oldman, took about an hour but isn’t too hard if you now what your doing, or you could do what some people on here have done and pay a qualified electrician to do it for you. But that costs money
I don’t now about the fogs, because they came with the car as part of a deal when I bought it new. But again you can get these from andyspares for £29 each brand new look for Clio 98>. Only thing is wiring them up because you will need to make a switch to turn them on and off?? I think you can buy the switch that goes on the stalk on the steering wheel from renault, but I would have thought fitting it and wiring it would be a mission.
Hope this helps, btw your car looks mint with silver bumpers, so tempted to do it myself.
Allan
