Do you have a picture of where it's going into? And which direction. I can assume the sharp, splined looking bit is going into the rack itself.
As a rule of thumb you always want to apply pressure to the same part where there is interference so for example image a wheel bearing being pressed into a hub - you don't want to apply pressure to the inner race as that will load up your bearings which is baaaaaad
You want to apply load on the outside, same for this part I'm just trying to understand which bits going where.
I've just realised and now I feel terrible, I never replied to your WhatsApp, sorry mate![]()
I see, removing it I guess you'd want to get a slide hammer on there depending on how tight it's pressed in and pull it out.Dont worry about it mate. You helped me here all is forgiven 😄
So the pressure will be at the gear, but due to the spool valve it can only go on and off one way through gear end, unless you were take it all apart which I dont want to have to do!
I have some sleeves coming, Ill post pics when I get themI see, removing it I guess you'd want to get a slide hammer on there depending on how tight it's pressed in and pull it out.
Pressing it in, it looks quite deep does the part that's coming off where the bearing is so I'd take a guess that the suitable thing would be the sleeves from a bearing kit. I know it's a long shot but if you find yourself Derby way if be happy to help/throw some stuff at it to swap
Is this your PMS rack?
Can't see the vid mate![]()
Cheers! Yes I thought that would be the right thing to do! Luckily not much more should have to be drilled out the housings.I'd try and drill towards the centre looking at that. There's a bit of stress on that and getting closer to the edge of that Ali will only give it more excuse to go kaboom😂
Top work though mate!
