How to remove glovebox door Ph2?
Car  200 cup & 106 GTi
There's a scratch on the glovebox in my trophy and i want to replace the door.
On most cars the whole glovebox unit comes out, but i can't see how on the clio, having had the top of the dash off, the glovebox is part of it. The door must come off on it's own.
Someone please enlighten me :rasp:
If its a similar design as the PH1 172 then you have to open the glovebox and in the botton corners you should be able to see the tabs that slide across to lock the door into place. Just slide them the other way and it will come off. Hope that makes sense.
