how wide Trophy 182
yeah sorry guy's im an idiot, yeah the track im guessing it is slightly wider? just wondering how much wider they are coz it seems that it is making a diff to the handling?????!!!!!?????
thanks
The Offset on the turinis is different to the 182 wheels increasing the track slightly. Cant remember what offset they are tho.
They are slightly different.
They run 0.6 neg camber and 1mm toe out on front + 1.6 neg camber and 1mm toe in on the rear
Toe settings same as the cup racers
Hmmm i'm pretty sure the 172 cup and the 182 Trophy have a 10mm wider track.
I've got no idea about the 172 cup, but the Trophy is the same as all other 182's. Same wishbones, same hubs, same wheel offset. The end.
The 172 Cup had a wider track than the 172 FF due to a different wheel offset (the cups Turini's were ET38.5). All the 182's have a wider track due to the position of the hubs and not by playing with the wheel offsets.
I stand corrected, not that it matters now i've sold my T
aren't the 182 cup/182 ff hubs different from the normal 182? they have the 60 mm bolt spacing
Sort of, my bad. All 182's with cup pack suspension and the Trophy's share the same hubs. The non-cup pack suspension 182's do have different hubs, and I'm not sure if that affects the track or not.
we should measure our cars, as these numbers are often hard to get :(
