Html / Java? (I think)
Car  2014 Focus Titanium
Hey guys,
I'm looking to enhance my website by having scrolling pictures which fade in and out through a series of say 4 or 5 pictures. Here is the website as it stands:
http://www.burstwickcountrygolf.co.uk/
Now this website is maintained and improved by myself, but done using a web contained management system. 90% of things I do are using a WYSIWYG editor in this system but there is the odd thing when I have to edit the CSS file or input a bit of HTML here and there.
I have basically learned how to do this by trial and error, looking at source code from other sites but I am barely competent! Here is the current CSS code for the header:
#header {
position: relative;
width: 1024px;
height: 300px;
display: block;
margin: 0 0px;
top: 0px;
z-index: 2;
background: url(/resources/25980/assets/images/Backgroundbanner3.jpg) repeat-x;
What java code would I need to put in to get the picture scrolling? Is it that simple?
Cheers!
Thanks Adamio, I have looked on there under Image Effects but I can't seem to find anything regarding fading pictures. :S
Java
var busy = false, timer, loadedImages = [], gallery = $('gallery'), progress = $('progress'), bar = $E('#progress .bar');
var path = 'http://demos111.mootools.net/demos/Asset.images/';
var images = [
path + 'cow1.png',
path + 'cow2.jpg',
path + 'cow3.jpg',
path + 'cow4.jpg',
path + 'cow5.jpg'
gallery.setStyles({'opacity': 0, 'display': 'none'});
progress.setStyle('visibility', 'hidden');
$('clear').setStyle('visibility', 'hidden');
$('start').addEvent('click', function(e) {
e = new Event(e).stop();
$('start').setStyle('visibility', 'hidden');
if (!busy) {
var galleryImgs = $$('#gallery img');
if (galleryImgs.length > 0) galleryImgs.each(function(image) { image.remove(); });
busy = true;
progress.setStyle('visibility', 'visible');
gallery.setStyle('display', 'block');
new Asset.images(images, {
onProgress: function(i) {
this.setStyles({
'position': 'absolute',
'opacity': 0,
'left': (gallery.getCoordinates().width / 2) - (this.width / 2),
'top': (gallery.getCoordinates().height / 2) - (this.height / 2)
loadedImages = this;
var percent = ((i + 1) * progress.getStyle('width').toInt()) / images.length;
bar.setStyle('width', percent).setHTML(i + 1 + ' / ' + images.length);
onComplete: function() {
var fx = $('gallery').effect('opacity').start(1);
timer = 0;
loadedImages.each(function(image, i) {
timer += 1500;
image.inject(gallery);
fx = function() {
var imgEffect = image.effect('opacity', {duration: 1500});
imgEffect.start(1).chain(function() {
if (i < loadedImages.length - 1) {
this.start(0).chain(function() {
image.remove();
} else {
busy = false;
$('clear').setStyle('visibility', 'visible');
}.delay(timer * 2);
$('clear').addEvent('click', function(e) {
if (!busy) {
$$('#gallery img').each(function(image) {
image.remove();
var fx = new Fx.Style(gallery, 'opacity', {
gallery.setStyle('display', 'none');
fx.start(0);
$('start').setStyle('visibility', 'visible');
Html
<h3>Asset.images</h3>
<p><a href="#" title="Start loading" id="start">start</a><a href="#" id="clear" title="Clear data">clear</a></p>
<p id="log"></p>
<br />
<div id="progress"><div class="bar"></div></div>
<div id="gallery"></div>
CSS
#gallery {
position: relative;
margin: 10px auto;
width: 500px;
height: 400px;
background: #2a2a2f;
border: 2px solid #5f5f5f;
#progress {
margin: 10px auto;
width: 200px;
height: 15px;
padding: 2px;
border: 2px solid #dfdfdf;
#progress .bar {
width: 0px;
text-align: center;
font-size: 10px;
height: 15px;
color: #fff;
font-weight: bold;
Look at Moo Tools
Thanks for the info Conneh, I just have a couple of questions. It would be easier for me to do this if I could edit the actual source code of the pages but I can't, it's through a contained manager.
Where would I put what?
<HEAD>
Global Header
CSS
Page itself
Is there no options to upload and download pages ? Or if not can you FTP in to the site ?
Then you could just copy the file off, do the changes on your machine (even if it's just in notepad) and stick them back up there.
Ideally you want to be able to access the code to add in the required JS that you are looking for.
If you dont get on with the above code I have a JS for images changing that i've used before I can try and dig out for you.
I can input the JS Code in the "Embed Code" bit which is essentially just in the <HEAD> on each page so not a problem. I would assume the HTML would go in the "Global Header" container and the CSS would go in the CSS editor.
The bit I don't understand is can I change the name of the "#gallery" to "#header" because that's what contained system uses as the header picture on the site? If so how do I change it so the JS understand #header instead of #gallery?
Ok so let's say I put the Java code in the <HEAD> section as well as the Div ID bit, like this:
<HEAD><script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.3.2/jquery.min.js"></script>
<script type="text/javascript" src="fadeslideshow.js">
* Ultimate Fade In Slideshow v2.0- (c) Dynamic Drive DHTML code library (www.dynamicdrive.com)
* This notice MUST stay intact for legal use
* Visit Dynamic Drive at http://www.dynamicdrive.com/ for this script and 100s more
</script>
<script type="text/javascript">
var mygallery=new fadeSlideShow({
wrapperid: "fadeshow1", //ID of blank DIV on page to house Slideshow
dimensions: [250, 180], //width/height of gallery in pixels. Should reflect dimensions of largest image
imagearray: [
["http://i26.tinypic.com/11l7ls0.jpg", "", "", "Nothing beats relaxing next to the pool when the weather is hot."],
["http://i29.tinypic.com/xp3hns.jpg", "http://en.wikipedia.org/wiki/Cave", "_new", "Some day I'd like to explore these caves!"],
["http://i30.tinypic.com/531q3n.jpg"],
["http://i31.tinypic.com/119w28m.jpg", "", "", "What a beautiful scene with everything changing colors."] //<--no trailing comma after very last image element!
displaymode: {type:'auto', pause:2500, cycles:0, wraparound:false},
persist: false, //remember last viewed slide and recall within same session?
fadeduration: 500, //transition duration (milliseconds)
descreveal: "ondemand",
togglerid: ""
var mygallery2=new fadeSlideShow({
wrapperid: "fadeshow2", //ID of blank DIV on page to house Slideshow
imagearray: [
displaymode: {type:'manual', pause:2500, cycles:0, wraparound:false},
descreveal: "always",
togglerid: "fadeshow2toggler"
</script>
<div id="fadeshow1"></div>
<br />
<div id="fadeshow2"></div>
<div id="fadeshow2toggler" style="width:250px; text-align:center; margin-top:10px">
<a href="#" class="prev"><img src="http://i31.tinypic.com/302rn5v.png" style="border-width:0" /></a> <span class="status" style="margin:0 50px; font-weight:bold"></span> <a href="#" class="next"><img src="http://i30.tinypic.com/lzkux.png" style="border-width:0" /></a>
</div>
</HEAD>
Then what do I change about the CCS? (Currently looks like this)
#header {
position: relative;
width: 1024px;
height: 300px;
display: block;
margin: 0 0px;
top: 0px;
z-index: 2;
background: url(/resources/25980/assets/images/Backgroundbanner2.jpg) repeat-x;
Help! :headno:
