Okay, I just tried to install a new alpine 9857R HU however I'm having problems getting the unit to work with the key out of the ignition. I have used the alpine loom and connected the yellow wire with the in line choke coil to the yellow wire on the the iso connector which connects to a +12.5v OEM wire already in the clio. The red ignition wire is connected to the red ignition wire on the iso connector which I have tested is 0v when the key is out but switches when the key is turned. I cannot however get the HU to operate with key out! Can anyone shed some light as to what I'm doing wrong? Does the unit require more than 12.5v to operate? The unit retains radio stations when the key is removed suggesting that it does have the constant power wired correctly.
