hubcentric spacers
  Mk2 Clio 1.6
quite alot of you guys have hubcentric spacers fitted. id like some so my wheels arent so burried into the arch as they are.
can anyone help as to what hubcentric spacers would fit? thanks
bit of a begginner i am
  Charged Superleggera
depends how much you want to space the wheels. if 5mm then no need for huncebtric but if you want 15-25mm then get hubcentric ones. get ones that are made for renaults which have hub spacing of 60.1mm and 4 stud. can easily be found on ebay.
yes they will fit. although i woudl advise you to buy system b spacers as they are safer and wont give you the wheel wobble.
Sam
North East
Mate. Do a stud conversion. Its so much more efficient!
Safer, Stronger, Cheaper, Easier!
Its just got more plus than just a spacer and some bolts!
PM if you want more details!
  Ultra Red Clio 197
Fitted 25mm hubcentric ones to my car over the weekend.. Needed them with the RS body parts and I dont notice any difference with the steering.. I got mine on eBay for £45.. Delta Mic is the brand, just like "JME's" above!
Yeah you're good to go. You might want to clean your hub before fitting them though, that way they won't make any noises. :)
