humming noise only at 68-72mph?
Car  sport 172 mk2
hi all, I have a humming noise comming from front of car, but only within the speeds of 68-72mph, and again at 80mph.
Don't think its engine related as i set the revs in a different gear and it doesn't do it, I even pushed in the clutch to lose the revs completely and it still hums.
I was thinking bearing as there is no vibration, but wouldn't I get it at lower speeds?
cheers
Sounds like wheel bearings if its road speed related rather than engine speed related.
The rear bearings, are a common problem and when worn, make a hell of a noise thats difficult to pin down when driving the car.
They are quite cheap to buy and relatively easy to replace.
Check the "guides" section of the board.
Might be a silly suggestion but could the humming maybe be your wipers ?
MIne make a noise but i need to be going just a tad faster ;)
Thought about wipers, but it does it when wipers are on and I would imagine that the noise would at least change a little during the arc of the wiper.
I'm thinking that it is bearing related, just thinking that the noise will start to be noticeable at lower speeds and then i can nail the sucker!!
