hydro clutch
is it advisable to take a feed off the brake fluid resevoir to the clutch master cylinder or is it better to get a seperate resevoir?
also if i take it off the brake resevoir as it only has 2 outputs how would i go about this?
cheers
  R5 gtt, R27 F1 team
your going to get an O2M conversion so why not use everything from VW?
Scoff knows what master cilinder you'll be needing btw
because its too much work lol. it'd be easier to have a seperate resevoir and plumb that in.
ive ordered what i bilieve is the correct master cylinder for this so its just a case of making it fit now
