dann2707
Hey.
I've taken my wheels off for spraying and noticed that on the nearside front, If I hold the disc at the sides or on the top and bottom I can wobble it quite a lot.
When I got the car it went for the MOT and was going to fail on the front left wheel bearing but I tightened the hub nut and that solved the issue the wobble was gone.
Is this related? Do the nuts come loose or has the bearing terminally failed?
Suspension and brakes etc really isn't my forte so i'm not sure what the fix would be? New ball joint?
Thanks. Can get a video if it helps
