i dont understand offsets etc...
Car  mk5 VDUB polo
could someone help me out with the info for what wheels can go on a clio? if that makes sense
like offsets and everything because i dont really understand
thanks
ok offset is measured from the centre line of the wheel (imagine cutting a wheel in half)
now the offset is the distance from the centreline to the hub face of the wheel measured in mm
so a wheel with an ET of 10 means the hub mounts 10mm from the centreline of the wheel which means the wheel sticks out
a wheel with offset of say ET60 mean the hub face is 60mm from the centre line, so the wheel is further in
have a look at a V6 clio next time you see one, they have the strangest offsets!! ET 6 up front and ET 68 rear!!!
or your clio you need wheels with an offset of between ET37-ET42 and PCD of 4x100 (which means 4 stud with 100mm spacing)
