i have between 220-300ish to spend on lowering
  Italian 3.2 V6
...dropping my 2004 1.4 clio by 60mm on 15" alloys with 195x45xR15, what do you suggest 2 go for, to get the best result from my money? I am not gna be using my car 4 track days, most hardcore driving will b using it hard on b roads (when safe ofcourse). So could do with semi decent gear tbh.
Or would a 60mm drop cause problems? If so please state. An what would b the next best max drop i could do without causing any problems.
Thanks. Hope u guys can help.
  Static Low
i had 60mm no problems at all. anywhere at anytime.
quite a nie drop though.
apex do good kits
Don't bother with spending on springs either spend a lot or not at all on suspension mods.
If you realy want get the eiback springs there the only ones I'd recomend if I realy had to.
60mm drop ins't a problem it will wear dampers and depnding upon which springs you use etc.
don't forget ride won't be as good.
  Italian 3.2 V6
ok thanks, wat type of price shud i be looking 2 pay?
any1 elsd got any good reviews etc on any suspension kits.
