i need help
i need to know how to make the the oil....something u know the thing thats on the dashbord,the three oil.showers temp,bar,how much oil there is
hope u understand i dont know the right words for it
how do i make the one in the middle work
try to explane gooooodddd pics are very useful
thax
That is the oil temp gauge, and iirc it is coupled with the oil level sender whihc is on the front of your block near the dip stick.
as ben says the oil level and temp use the same gauge.the oil level gauge works for about 10secs when you first put the ing on,after that the gauge shows oil temp.if oil level doesnt work its probably a fault with the level sensor(sensor circuit in open circuit)
if the gauge doesnt work then replace the oil level sensor first.it is in the block at the front of the engine with the connector pointing up. the reason the other two work is there information comes from different sensors and they are on different wiring circuits.
dont u have any pictures? of where i shuld look because i am from sweden and i dont use same english u do so it is hard for me to understand every part u say
plz
sorry,i have no way of posting pics im afraid.cant you buy clio repair manuals over there because there would be a picture in one of those.
the picture is a different engine but the sensor is in the same place on yours which is what ben is trying to show you.look on your engine where the arrow is pointing on that picture.
