help please i can smell petrol inside my car it only started when i filled up the other day, i've looked for leaks and loose connections under the bonnet and under the car and found nothing
Its the small diameter pipe that drains any overfill from the filler neck, just inside the filler flap.
It should run out under the car but if the pipe comes off it can run down inside.
any chance anyone has a pic of where the overflow pipe is as i cant find it on mine so im thinking it has fell off and cant see where its ment to go
and the boot floor is wet with petrol
