Ph1 track 172
Right, after not having a sub in my car for about a month,
i finally get another jbl 1201.1 amp,
i install it, but dont get to blast it at all, (the mrs dont like it)
but today i was with my mate,
and we turned it up, and it cuts out,
keep it a very low volume, its fine.
the amp was last used in my mates car, i helped him take it out i know it was fine before it left him, it sat on top of his wardrobe for a month or two, but thats all,
ive had the exact same setup in that car before, and it worked fine, a hell of a lot louder than it is now,
i dont believe its the wiring, as the other amp (jbl 75.4) isnt setting a foot wrong, its wired with 0awg to a dist block, then 4awg to the amp,
with a 100a fuse, (but as ive said, this setup has worked for ages.
due to the sub playing at low volumes, i dont think theres a short in the speaker wire, and ive watched the amp flick onto protect mode (protect light just flashes, but sub cuts out for longer) so i dont think its the headunit or remote.
i did my investigating, and its worse (cuts out at a lower volume) with the engine off, and even worse with the engine off and lights on, aux belts are due a change, but theyre making no noises of slipping,
also it has an upgraded battery only a year ago so i dont think its that either.
could my alternator (oem) be on its last legs??
opinion on what my course of action should be,
going to do the aux belts this weekend and see if they make a difference.
if only i had a batman style WALLOP light to shine.
