ice problems!!!
right, im having a re-occurance of a problem i had couple of weeks ago, when system turned up loud, big amp shuts down, even when driving (with fuse box and power cap both showing volts between 12-14), the battery light keeps flashing! could my amp be knackered? why would this cause battery light to flash on?, surely when driving battery size/power should not be an issue?? do i need a bigger battery?? soz 4 the essay, cheers
i meant to mention, had an alarm fitted a couple of weeks ago, this is roughly when the problem first started, coincidence? cheers
I think I replied to your question when you first had the problem. It sound to me like too much of a coincidence with having the alarm fitted and now having problems. Have you taken it back to the alarm fitters yet?
Russ
right, just phoned the alarm people, they said that if the alarm was on solid for 6 months it would not drain the battery, he said to check the alternator, so i did, fine, so i got a larger battery (44 amp to 55 amp), and new terminals, and it seems much better, cheers for your help about this problem
