ice
Car  mk2ph1 rsi 106rallye
what size are the standered speakers in a 2000 plate clio rsi?
what aftermaket headunits work with the steering wheel controls?
The Mk2 Ph1 standard door speakers are 5.25" (13cm).
Re. Steering controls, most main manufacturers will work. You have to buy the adaptors seperately, First the steering control module thing itself, then the adaptor that adapts that to your make of headunit.
So brands like Sony/Alpine etc should work. Its around £40 for the adaptors I tihnk
Depends. If there are rear speakers fitted, they will be the same size as the fronts. You'll have to check yours though not all models came with rear speakers.
As to tweeters, I don't know if ph1 have tweeters? I think they do, they'd be in the dash either side.
