idle control sensor
  clio 172
hi i have just bought a load of stuff for my car 1 is a idle control sensior can enybody please help and tell me where it is in the car as i carnt find it atall and rely want to fit this new one today .,meny thanks louis ;)
2002 172 2.0 16v
Re: idle control sensior
The culprit will probably be the Idle Control Valve (ICV) which is located on the top of the inlet manifold. The ICV acts as a gate allowing varying amounts of air into the engine. However they are known to stick. Then they either let too much air into the engine, possibly causing high revs, or not enough starving it of air and causing the engine to almost or actually cut out.
Solution
Remove the wiring connector and three bolts that hold the ICV in place. Liberally spray it with carb cleaner using a small brush to remove any deposits. A new O-ring will be required for reinstallation.
IS THIS THE SAME THING sensior and valve
