Rojer
Hey there just bought my first clio 1.2 mk2 phase 1 on a x plate. Drove it home from london fine, opened the botton the engine was covered in oil and no powersteering fluid. So took it into college flushed engine and changed oil also flushed the cooling system and then changed oil filter which had never been done. Needed rear section exhuast aswell and did a few other little bits. But the leak wasnt coming from the oil filter it was coming from above it so any ideas? The head and the cambelt was done 10,000miles ago and full service. Also the headunit wiring is shocking so need to sort that and few other bits. SO help please going to change the plugs see if that helps.
