idle speed control valve
Anyone know if the idle spped control valve is the same on all mk1 clios? I need one for my rsi.
After talking to renault several times about it and being given 3 different prices for, suposedly, the same item I have no faith in my local renault garge to actually order the correct part! Especially when they turn round and say whats an idle speed control valve?
So im after a used one.
  Renault Clio 1.8 RSi
hey dude,
as it happens my new one just arrived in the post today.
go here http://www.partsgateway.co.uk/cgi-bin/dm_parts.cgi?VehicleType=Modern&Selected=64+254+65+8&Manufacturer=Renault&PartsForm=1&contact.x=52&contact.y=12http://www.partsgateway.co.uk/cgi-bin/dm_parts.cgi?VehicleType=Modern&Selected=64+254+65+8&Manufacturer=Renault&PartsForm=1&contact.x=52&contact.y=12
and put in what youre looking for, you should get about 3 or 4 companies contact you with different prices.
i paid £20 + delivery for mine, a bit better than £165 + VAT + Labour that Renault wanted for one!
  GDI Demo 182, Rsi Spider
there should be a bosch part number on the side starting with 0 280
make sure the numbers match up on the part you are getting otherwise the flow rates and pin configurations might not be correct
Andy
GDI
  172 cup,s2 rs turbo
the idle valve is different on the rsi compared to other clios because it is a laguna engine(the 1.2/1.4s use a stepper moter not an air valve).any 1.8/2.0 8 valve laguna will have the same valve.
