Illustrator help!
Car  Golf GTi MkV
How the hell do you change the colour of the dotted line brush from black? Racking my head for the last hour, gotta be something simple.
Thanks in advance if anyone knows this.
I can help, but where I can find the "dot line brush"?? I never seen that.
From the tool box, there are 2 squares at the bottom, one is fill color and one is outline/stroke color. Click "X" can switch the square. I think you select the stroke and select the color from swatch libary, you will be fine.
Pls let me know if you have problem.
Yea, thought was the obvious stroke pallette, but its not. applied the dotted line brush to my rectangle and it's like the cut-out dotted line. Changing stroke colour doesn't change it, odd I though.
select the brush in the brush palette - then top right of palette select the options and go to Art Brush Options and change the key colour.
Also make sure you got the colour u want it to be selected as stroke colour then in the key colour options use hue i think.
