I'm guessing my driveshaft is pretty much knackerd *video inside*
  Focus RS + S3
braved the cold to investigate my knocking and found this, im assuming this has basically had it ?
  Focus RS + S3
Hmm thats strange then, means i got sonething else knocking :-(
Thanks for the replies
  Arctic Blue FF 182
Checked bottom ball joints? They bolted up tight, seen a few stories of them knocking on here
  182
^ yup, time to rule out your bottom ball-joints by levering with a large jemmy bar between the arm and the hub-carrier knuckle. If any vertical movement then it needs replacing (it could just be un-tight but its more likely to be seised in the pinch bolt than be loose in my experience)
  Focus RS + S3
Yeah, im trying to find two knocks haha
so in my other thread i got another video, i got new ball joints, track rod ends and solid top mounts
Just want to give up :-(
  Golf gti ED30+182
did you get any noise from the front when setting off like a banging as it could well be the cv joint on the drive shaft that banging
  Focus RS + S3
its when i go over bumps, it rattles and sounds like the nosie in the video as i move the shaft left to right, funny you should say cv, the boot was loose last week to put some grease in and clipped it back on
  Focus RS + S3
ive wiggled the wheel all ways in the air, and there seems to be nothing, ill try in on the floor
this is now and again, when driving, in a straight line and corners its fine, as soon as the road gets bumpy (majority of roads down here) it knocks, then 'rattels' afterwards, im pretty sure its drivers side, so when i moved the shaft yesterday and found that nosie i thought i was onto a winner,
as the passenger side moves a minimal amount and doesnt 'clunk' whereas the drivers side shaft in the video had a fair amount of play in it which is hard to see, and the knocks are made from pushing the shaft into the CV, 'clunk' pull out towards box and it clunks again, and its pretty loud
