I believe it cranks yes, for about 3 seconds or so and then stops
Battery is good , immobiliser flashes slowly when car locked & flashes faster when ignition on.check battery voltage is ok, standing and on cranking.
does immobiliser light flash at same speed or faster with ignition on?
Thank you, I'll check in the morning..that's key not recognised.
if it's not cranking as well then check the main loom earth top of the gearbox just above passengers drive shaft.
All earth's checked & in position ( tight/dine up) the only earth that I would question is the 1 from the bottom of the engine (n/s) going to Chassis behind (n/s) front wheel. It's about 6" long braided wire, wasn't loose or fraided in any way just the colour it was puzzled me (greenish/grey). But as I said all in tact. You mentioned earlier in this post possibly key not recognised. Would this apply to both keys? As neither key works.. Just seems a little odd that it was a daily ride for my daughter up until 2 weeks ago..Thank you, I'll check in the morning..
Thanks for that.. I had the board out the other day & that seemed fine...How do I recode both keys as neither work.? Is that a Renault dealer for a " paints down penetration " expensive moment.??Sounds like the key has lost its coding or the UCH has got water into it
Yep took the UCH out of its housing, all clean and dry... The bloke who owned the car before my daughter had the board tested at a diagnostic centre ( I've got the paperwork) apparently they plug/connect the board to a computer & test all circuits.. That was done Nov 2015.. But you reckon a mobile guy should be able to sort the key coding out..? Thanks for all the help..Did you strip the UCH down to inspect it? and for re-coding keys most decent mobile diagnostic guys should be able to sort it for you .
Thanks for the help, much appreciated..Yeh any decent mobile diagnostic guy should be able to sort that for you , or the other option is buy a set off ebay they aren't that expensive , just make sure you get the engine ecu , the uch , barrel pickup ring and key fobs , to be honest that might be the cheaper option .
