immobiliser question
Car  F4R'd ITB'd '92 cup racer
on a 172/182 if the immobiliser is armed does it let the fuel pump prime on ignition?
I think it does prime.
But the injectors/coil pack are immobilised.
I'll let you know next time mine plays up!
Lol Thanks. We have a 1.2 that has an immobiliser problem we think. It unlocks fine, all the dash lights come on as should, the immob light flashes fast and wont turn over... any ideas?
Does it ever start?
Try changing the battery in the key. Mine was playing up, but I changed the battery, and bent the connection tabs out so it's making better contact and so far so good.
I've had this problem recently and my answer to this is no, it doesn't.
Obviously I'm no mechanic but from my experience with this it only ever primed when the light went out. That's when I knew I could start it.
If anyone is having this problem I highly recommend you replace the two black ignition relays under the bonnet on the right hand side.
New ones only from Renault circa £18 each. I tried swapping them around etc but only when I put new ones in did it fix the issue.
Your barking up the wrong tree with changing batterys in the fob.
