Errr, try on the cliosportsclub yahoo group, theres always a bit of a debate on there about changing thermostat switches for one from a 5GTT. Dont know if it works properly though...
Have you tried simply draining the system and washing it through? I done this to mine and it ran like a dream (although Ive got anougher prob with something else now!!)
you could buy and fit a Pacet fan on as it draws air in muc faster,and i wouldnt fit moe and a 3 deg cooler thermo as theyre meant to run at the original thermos temp!
alternatively, you could buy a heat exchange unit. Basically it heats the engine faster and cools it better. It works by passing oil and water close together past a thin metal membrane (no it wont leak). When you statrt the cold engine, water heats up faster, the heat is the passed into the oil, providing better protection nd faster warm ups. When the oil is hot, it can pass this heat onto the water system, thus keeping the oil at the optimim thermostats temp....justan idea.
