D'you mean it sometimes flashes rapidly and the rest of the time normally? I had this, try pulling the contacts out a bit in the indicator bulb holders as if a bulb is loose it can sometimes break the circuit causing the rapid flash
It's the module that controls certain electrics on your car (lights, wipers, windows etc etc) The relays can fail resulting in the car doing strange things. My bro's went funny and would indicate right all the time unless you were indicating left. Do a search on here, it's quite common.
