looking to get;
MOMO Race Evo Aluminium "S" Type £36.21
Just incase anyone needs to know all MOMO's with an "S" in the name are designed for lift up reverse
and
MOMO Match Anthracite
to go in my 2002 1.6 Dynamique
Ive done a search on here and read through all the infomation i could find and its a little vague considering how hard it sounds. I was wondering if someone could give a bit more of a detailed guide as how to do it before i take a hacksaw to my gear stick and a drill to my pedals.
Cant work out whether it would look better to just leave the pedals black rubber as they are, want my car looking classy not chavy?
My gear stick has a black plastic insert rather than a aluminium one, dont know if it is moulded into the knob or not but will be able to just saw through it, if needs be.
are you removing and replacing the little things you pull up to go into reverse or does the new knob sit on top?
Is the gear stick going to be shorter in height once i have replaced it?
I am also thinking about replacing my inside door handles as the lever is currently black plastic. Are the silver ones made of metal or just sprayed plastic?
Should i buy a set of second hand handles or just spray the levels on my current ones?
how hard are they to fit new ones?
and
