Injector voltage
I’m having trouble with a F4rt
It’s just dying and cutting out when you rev it up or go to pull away
It’s got 4 new coils
I’ve removed one injector plug at a time when it’s running and I’ve got 14v on one wire and 2.5v on the other wire
Is this normal ? I was only expecting 14v on one wire
Cutting out when revving sounds like a sensor issue.
Possibly the crank sensor.
I’ve tried a new crank sensor and it’s still the same to be honest
Is there anything else worth changing ?
It will sit and rev standing still but when you go to pull away it just pretty much dies
Also seems to be a bit better when the engines first started from cold
